Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problems after installing doms rear lca's
Old 11-28-2012, 10:17 AM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,944, Level 94
Points: 23,944, Level: 94 Points: 23,944, Level: 94 Points: 23,944, Level: 94
Level Up 60% Completed
Forum Activity 100%
FF Reputation: 79 felixthecat Excellent Standing Member
Any time you put the suspension apart you need to do a alignment. Before you add the toe-links make sure you add boots to them to protect the heim joints from dirt/dust & do not grease or oil them up. Then the tech will adjust your camber & then the toe on the rear first & then adjust the toe on the front after doing the rear, w/ getting the s/w straight. As far as the rear height & the spring perchs all the way down, the only thing left is to run shorter springs. I've seen where the springs perchs are set a few inches from the bottom & the car was sitting pretty low. Be interested in where he figured the height of the perches compared to the stock arms. Did you get a chance to compare his arms & the stock ones side by side? Just looking in pix the stock arms have pretty low spring pockets.
felixthecat is offline
