Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problems after installing doms rear lca's
Old 11-28-2012, 09:23 AM   #1
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
Points 6,372, Level 52
Points: 6,372, Level: 52 Points: 6,372, Level: 52 Points: 6,372, Level: 52
Level Up 11% Completed
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
The car seems to sit a bit higher with the perches all the way down, and also after a quick test drive felt like the rear was wobbly as hell. I gave a look (knowing the alignment was off obviously changing then out) but then actual rear tires are pointed inward as well as the rear of the the rear tires (hope i dont confuse) being pointed outward.) I have adjustable toe links I am installing tomorrow, and was wondering if an alignment would straighten on the tires to run straight, not pointed inward in the rear as they are now. The steering wheel does need to be held at a slight angle at certain speeds to drive straight.
Thanks
Sent from my SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
