Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 focus air in lines after brake job
Old 11-27-2012, 11:54 PM   #10
Geezer
Fan#: 1427
Originally Posted by ghostrider_14 View Post
yep fluid and air still comes out.
How much new fluid have you used? An average bleed uses 12 to 16 oz. If you haven't used that much bleed again.
Since a caliper was replaced double check all hose connections for tightness, kinking, etc. I'm assuming the new caliper is functioning properly (no leaks in piston seals and internal fluid passages are unobstructed). If this is the case, the problem may be the actual bleeding procedure and potential mistakes. What bleeding process are you using?
Geezer is offline
