Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clutch, Rack & Pinion, and more
Old 11-27-2012, 11:20 PM   #2
PLRX
PLRX's Avatar
Fan#: 16768
What I Drive: 2003 - ZX5 - 5 Spd - 2.3 Duratec
Points 1,677, Level 23
Points: 1,677, Level: 23 Points: 1,677, Level: 23 Points: 1,677, Level: 23
Level Up 77% Completed
FF Reputation: 1 PLRX Good Standing Member
The old PS pump was making that infamous sound, and decided to install a "new" one.
Remove the belt cover, and remove the belt.
Remove headlight, PS pump line, and upper coolant reservoir lines
Use a pulley
Remove bottom PS line, then remove the four bolts.
Put it back on reverse order. Torque bolts to 17 lbs-ft
2003 ZX5 HID Lights, Interior Carbon Fiber, Poly Bushings, SVT Suspension, Upper Strut Bar, Euro SVT Wheels,
SVT Brakes, Steel Braided Brake Lines, Drilled Rotors, K&N FIPK Generation 2 and Magnaflow Cat-Back
PLRX is offline
