Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is anybody ever going to do anything with these n/a engines?
Old 11-26-2012, 04:38 PM   #13
Fan#: 105916
What I Drive: MK3 FocusHatch 5SPD, '93 RHD WRX
Points 183, Level 3
Points: 183, Level: 3 Points: 183, Level: 3 Points: 183, Level: 3
Level Up 66% Completed
FF Reputation: 1 Tommyatomic Good Standing Member
Originally Posted by amoosenamedhank View Post
I'm not sure the logic in the ECU's are all that similar. The N/A focus uses a MAF sensor while the ST uses 3 MAP sensors. (speed density).
Completely different logic.
Different sensor.
Different Fuel tables because NA vs Turbo means different compression
Also additional tables for factory boost control map
Doesnt matter.
Its not an actual issue unless you want some sort of mailorder chip like from the 1990's. I assure you that you dont want that.
Once there is any actual tuning option for the Ti-VCT ecu's there will be options to load different fuel and ignition tables regardless of sensors.
Once there's tuning for the Ti-VCT pretty much sky's the limit for optimized bolt on tuning and packages for bolton forced induction kits.
Its a pretty safe bet that some suit at Ford asked Cobb and SCT and Roush and whom ever else not to release any aftermarket tuning until the Focus ST is firmly marketed in north america.
Tommyatomic is offline
