Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Injen sp series intake installed
Old 11-26-2012, 01:02 PM   #25
Fan#: 105916
What I Drive: MK3 FocusHatch 5SPD, '93 RHD WRX
Points 183, Level 3
Points: 183, Level: 3 Points: 183, Level: 3 Points: 183, Level: 3
Level Up 66% Completed
FF Reputation: 1 Tommyatomic Good Standing Member
Originally Posted by StockTalon View Post
Ideally, you would want to run plastic since it wont absorb heat like metal will.
hot plastic disagrees with you.
Seriously though hot plastic takes longer to dissapate heat than the same shape/amount of hot metal. But metal is a heat transfer medium. Depending on the finish and the coatings (ceramic for instance) metal is heat reflective.
Its possible that your not talking about polycarb, PVC or ABS plastic. Maybe your saying plastic and your actually thinking molded silicon which neither absorbs heat nor transfers heat. I have molded silicon potholders and oven mitts.
Metal vs plastic intake discussions are the stuff of internet boredom.
Tommyatomic is offline
