Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Running 12GA speaker wire into the doors ???
Old 11-25-2012, 08:24 PM   #1
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Hello,
Today I attempted to install my new ID CXS65 components into my 2012 Focus. I had read on this forum that it is very difficult to run speaker wire into the doors due to the mylex connection on the factory boot between the door and body so I was planning on drilling new holes, using grommets and running the wire through the new holes. Once I looked under the steering wheel by the hood release lever, I do not see how this is possible... How do you get to the inside of the door jamb? There is a peice of metal that all the insulation is attached to under there and that is approx 8" from the inside of the door jamb! I beleive a forum member named Storis has done this on his Focus. Can someone please tell me what I am missing? I am also adding an amp so I really do not want to use the thin factory wire... Help Please!!!!! (Hopefully I am explaining my problem good enough) I need to know how to get the speaker wire into the door...
Besbro is offline
