Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Front End Clunking
Old 11-25-2012, 07:03 PM   #2
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
Points 6,372, Level 52
Points: 6,372, Level: 52 Points: 6,372, Level: 52 Points: 6,372, Level: 52
Level Up 11% Completed
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
First of all, I doubt its the bar being off centered or even the bushings. I'd check the sway bar end links that go bad after 60k or so and being lowered makes them wear faster. Replace those and see if the noise goes away. If it doesn't, check your strut bar upper mounts. Make sure the lock nut is super tight. Again, if you've changed your struts/ shocks and reused them or even not tightening them enough (most think they are but aren't) will make noise. If its neither of those then I'd check the bar being off centered, but unless you hit something crazy then I highly doubt the bars off centered. Good luck. Also mileage? Have you changed out any suspension things before? If so, what? More info will help!
Sent from my SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
