Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replace master cylinder clutch
Old 11-25-2012, 01:44 PM   #113
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,335, Level 29
Points: 2,335, Level: 29 Points: 2,335, Level: 29 Points: 2,335, Level: 29
Level Up 24% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 1 LugNut Good Standing Member
I just replaced the clutch master cylinder yesterday in the 2001 SE -- the OP's pics and descriptions helped as did the FSM.
I didn't need to remove the seat, nor the clutch pedal or the two or three colored switches. Did remove the clutch safety switch, and then carefully bent its bracket 45 degrees down to allow the master cylinder to come out and the new one to go in. The upper (of two) mounting bolt for the master cylinder was the biggest pain of the job.
After gravity-flushing the brake fluid, I used the fish-tank tube from the bleed-port to the fluid reservior technique for bleeding. Took 100 or more pumps to clear the fluid.
The replacement clutch master cylinder, $35 from AutoZone (PN 51370), was a LuK that was identical to the original 2001 LuK part that was removed.
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
