Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - temperature gauge reading lower than normal
Old 11-24-2012, 11:22 PM   #6
amc49
Fan#: 96610
Points 6,538, Level 52
Points: 6,538, Level: 52 Points: 6,538, Level: 52 Points: 6,538, Level: 52
Level Up 94% Completed
Forum Activity 80%
Activity: 80% Activity: 80% Activity: 80%
There is a small hole toward outer edge of stat, if straight up as it should be the system bleeds almost instantly. 5 minutes more than enough.
No way do air pockets make for underheating, rather they do the opposite as do any pressure leaks as a result of the broken plastic hose. That bleeds quick too.
OEM stat opening and closing mean nothing, you must check for absolute 100% closed when cold if chasing your too cold problem.
amc49 is offline
