Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 06 2.0 into 04 2.3 engine swap?
Old 11-22-2012, 10:34 PM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,576, Level 96
Points: 25,576, Level: 96 Points: 25,576, Level: 96 Points: 25,576, Level: 96
Level Up 23% Completed
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Originally Posted by timbowabo View Post
Good info felixthecat. Thank you.
I'm going to move forward with the job.
The two cars are not currently available for a side by side comparison.
What would happen if I did a straight swap without changing the head as suggested?
Would it be easier/cheaper to switch the pcm out rather than putting the 2.3 manifold on the 2.0? I have the entire 2006 2.0 at my disposal. The damage didn't affect the engine at all.
You could try it right now by switching the pcm's & seeing if they run. I don't think its going to work w/ the imtv that the 23 has. I know you'll have your car down, but to speed it up, pull the 23 out & remove the head, clean it up for the 20 motor w/ intake manifold.
felixthecat is offline
