Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Engine vibration NOT mounts
Old 11-22-2012, 03:01 PM   #15
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,586, Level 100
Points: 30,586, Level: 100 Points: 30,586, Level: 100 Points: 30,586, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
Engine operation seems to be the place to keep looking when you can.
Starting simple, and checking basics, will at least rule out some possibilities - and it's normal maint. you'd do sometime anyways.
Such as:
1. Pull plugs, check deposits & condition, check wires & coil.
2.Run a compression test while the plugs are out for baseline numbers & to rule out mechanical issues.
3. A little deeper, consider checking cam timing - especially if the belt is getting a bit "old".
4. Off track a bit, check the serpentine & everything it drives to make sure things are turning smoothly - something to look at if it turns out your timing belt is due for replacement. Don't want to miss a possible issue by skipping right past it!
5. And anytime you happen to peek under the hood, just look at things to see if they look "right". Wiring connectors & routing, same for vacuum connections & lines, it HAD run right before - so we're looking for anything that might have given up the ghost or been damaged somehow....
Luck!
sailor is offline
