Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2013 engine "click click whir" (engine not running)
Old 11-22-2012, 12:29 PM   #48
Defender
Fan#: 106391
What I Drive: 2013 Titanium HB (White Platinum)
Points 122, Level 2
Points: 122, Level: 2 Points: 122, Level: 2 Points: 122, Level: 2
Level Up 44% Completed
Forum Activity 3%
FF Reputation: 1 Defender Good Standing Member
Originally Posted by rzero0101 View Post
"More than likely the noise you are hearing is the shift fork actuator motors resetting in the transmission. Unlocking the door starts this process. When the shifter is placed in park and the engine shut off, the computer places the transmission in gear and releases both clutches. When the door is unlocked the computer begins resetting the shift fork motors and clutch motors in preparation for engine start. This is directly from Ford:
2013 Focus vehicles equipped with the Powershift DPS6 transmission may
experience a clicking noise from the transmission after the doors are unlocked and prior to the engine starting for up to 3 minutes. The noise is the transmission shift motors waking up and preparing for startup. Attempts to eliminate the noise should not be made."
Can you supply us the link where you found this info?
Defender is offline
