Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can you overtighten axle nuts?
Old 11-22-2012, 10:00 AM   #18
JCH841's Avatar
Fan#: 79303
What I Drive: 2013 Blue ST3
Points 906, Level 16
Points: 906, Level: 16 Points: 906, Level: 16 Points: 906, Level: 16
Level Up 6% Completed
FF Reputation: 3 JCH841 Good Standing Member
First of all, it is possible to overtighten anything; that's why they make torque wrenches. Likely not the problem here, but we had a crankshaft failure in a 6000 hp diesel because the factory (over) tightened the connecting rod bolts to the same torque as the main bearing caps and distorted the bearing caps. Most threaded fasteners will develop some adhesion in service; rust, corrosion, heat cycling such that the disassembly torque is likely higher than the assembly torque. In this case if there are any residual stresses or minute fractures from manufacturing/rolling threads, gross overtightening could precipitate a fracture failure.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
