Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus SE Hatchback Sport - Changing stock speakers
Old 11-21-2012, 05:31 PM   #68
focusstu
Fan#: 103157
What I Drive: 2012 Oxford White Focus S 5MT
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 2 focusstu Good Standing Member
Originally Posted by TboneZX3 View Post
Did you buy speaker adapters, or use the factory speaker frames for adapters?
I installed Infinity 6032si's in the front last week. I also used the factory frames and it does come out looking good, especially being able to use the factory connectors. When I tried the Infinity frames, there were some gaps between the frame and the hole in the door. Someone earlier in this thread or another thread used Scosche frames. They looked a little wider.
I had to cut notches at the edge of the factory frame to fit the tabs in the speaker where the screws go. The only thing I had to be careful with was to offset the speaker terminals from the factory frame terminals. Otherwise one of the holes drilled to attach the speaker would have gone right through the factory connector. If I ever remove the door panel again I will put some loctite on the screws also.
focusstu is offline
