Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2013 engine "click click whir" (engine not running)
Old 11-21-2012, 09:11 AM   #41
rzero0101
Fan#: 106497
What I Drive: 2013, Silver, Focus Se
FF Reputation: 1 rzero0101 Good Standing Member
Same Issue
I have the same issue and I don't feel whatever this noise is should be considered normal. I plan to take mine in sometime in the next couple weeks so the dealer can take a look. I found the following on another site.
"More than likely the noise you are hearing is the shift fork actuator motors resetting in the transmission. Unlocking the door starts this process. When the shifter is placed in park and the engine shut off, the computer places the transmission in gear and releases both clutches. When the door is unlocked the computer begins resetting the shift fork motors and clutch motors in preparation for engine start. This is directly from Ford:
2013 Focus vehicles equipped with the Powershift DPS6 transmission may
experience a clicking noise from the transmission after the doors are unlocked and prior to the engine starting for up to 3 minutes. The noise is the transmission shift motors waking up and preparing for startup. Attempts to eliminate the noise should not be made."
rzero0101 is offline
