Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - DCT issue/ Rear Main Seal
Old 11-21-2012, 08:46 AM   #14
dan50
Fan#: 91789
Points 4,225, Level 41
Level Up 38% Completed
Originally Posted by Shorty Long View Post
seems more and more likely that significant transmission problems will occur on an early build at some point for many if not most owners...it's not a matter of if but when. is this a major design flaw? should i drive around with my breath held as I move up past 25k on my car?
The problems described here seem to be mostly clutch-related, either from oil on the clutch plates or bad programming. If the symptoms are abrupt engagement, clutch chatter, etc., the trans itself shouldn't be harmed and should lead a long and uneventful life. Grinding noises though could mean gears are clashing in a way that puts metal bits in the gearbox fluid, which can't be helpful. So I guess it depends.
Most manufacturers are pretty good about extending warranties on components with an abnormally high rate of failure. Let's hope Ford will "step-up" if DCTs start failing even though they don't seem to care much if they're merely unpleasant to drive.
dan50 is offline
