Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can you overtighten axle nuts?
Old 11-21-2012, 05:22 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,663, Level 100
Points: 32,663, Level: 100 Points: 32,663, Level: 100 Points: 32,663, Level: 100
Forum Activity 38%
That will be fine. It could be bearings, buuuuut why not check? Hub bearings don't act like bearings on a spindle, so I think the best way to check is to jack up the vehicle by the frame, put trans in N, and spin the wheel. Listen for sounds. A bearing sound will be a low sort of grumbling or gravelly sound at the outer edge of the wheel. You'll hear brake scrape- of course, so ignore that. Now if you hear a rapid clicking from under the car somewhere, then yes, whomever installed your axles put too much force on the axle to push it in, and now the inner CV is broken. I've not heard of whirring with this particular failure, and I had it on my car for like 120k some miles before I got around to fixing it.
Whirring.... I think I should know that one, but just can't think of it ATM. Have you double checked to see if something is rubbing under there? AHHHH..... have you checked the passenger side carrier bearing to see if it is held down by it's strap?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
