Old 11-20-2012, 10:40 PM   #1593
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by FordCustomerService View Post
Hi 3focuslater,
The SE sports package doesn't modify the suspension; it'll be the same as the other 2012 SE models. If you'd like, I'm happy to get your case escalated to your regional customer service manager. Just send me a PM with your VIN, dealer, mileage, daytime phone number, and full name; I'll do the rest.
Crystal
Crystal, here are some part numbers for the various 2012 Focus suspension configurations. The suspensions types are the same(ie. MacPherson strut up front and Control Blade in back), but different struts/shocks and springs combinations are used throughout the lineup. An SE Sport uses a touring strut and shock, same as the TI base, however they both use different springs in the rear. The S, SE base, and SEL use the standard struts/shocks. The SE Sport and TI base uses the touring struts/shocks. The Ti handling uses Handling struts/shocks. Most models use the same rear spring, some use the same front spring, and the Ti Handling uses a front spring specific to that model only.
Originally Posted by kam327 View Post
Here's a similar version of it I just found:
This is compiled from checking dealer inventory VINs in Etis, parts lists from Fordparts.com, and information from other posters. It is interesting to see how the different models are packaged. It also makes me wonder if there are errors in Etis. For example, I don't see the "MD" rear springs being used with any model, but I expected them to be used on the Titanium with 18" wheels. Also, the SE Sport uses the S rear springs?
There is no difference between hatch and sedan suspensions.
All models use the same stabilizer bars - 23.5mm front and 19mm rear.
Both suspension packages use standard brake calipers and pads.
There are two different front lower control arms - one for the S model (15" wheels) and one for all other models (16", 17" and I assume 18" wheels).
Front suspension knuckles are the same, but different rear (I think) suspension knuckles for 18" wheels.
S
6 x 15" Steel Wheels
standard suspension (shocks)
BV61-5310-NF* Left Front Coil
BV61-5310-NF* Right Front Coil
BV61-5560-NF* Left Rear Coil Spring
BV61-5560-NF* Right Rr Coil Spring
SE
With 6.5J X 16" Steel Wheel
BV61-5310-NG* Left Front Coil
BV61-5310-NG* Right Front Coil
BV61-5560-NG* Left Rear Coil Spring
BV61-5560-NG* Right Rr Coil Spring
SE - sport package
7 X 16" Alloy ET 50MM Style 2
touring suspension (shocks)
SEL
7 X 16" Alloy Wheels
Titanium
7J X 17" Style 5 Alloy Wheel
Titanium - 18" alloy wheels
8 X 18 ET 55MM Alloy Style 2
With Handling Suspension (shocks)
BV61-5310-MD* Left Front Coil
BV61-5310-MD* Right Front Coil
Sonic's Mk3 Crew #11
Hatch Nation#163
TiStick is offline
