Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Low MPG on new 2012 Titanium Hatch
Old 11-20-2012, 04:19 PM   #99
HuskerFocus
Fan#: 100149
What I Drive: 2012, Ingot Silver, SEL Hatch
FF Reputation: 1 HuskerFocus Good Standing Member
Again S automatic only goes to 5th gear, but if you engage S + manual mode by using the shifter to shift into 6th manually you lock the car into gear until the engine speed is either too high or too low for a given gear when it will still over ride you by shifting if it thinks you have too little engine load for a given speed while demanding acceleration, or at 1100ish on deceleration if you do not shift it back down through the gears.
S manual goes through all the gears, but S auto (when it also does not display the current gear selection) only goes to 5th gear.
Yep, I should have clarified, I was in "automatic" mode
Vehicles: 2012 Focus SEL - Ingot Silver - +MyFord Touch
Mods: Drop in K&N Air filter, 30% Tint
Build Date: 12/19/2011
HuskerFocus is offline
