Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Headlight housing removal w/ sidelight bulb change (European)
Old 11-20-2012, 03:10 PM   #15
ksearcy
Fan#: 92627
What I Drive: 2012 metalic sterling gray sel
FF Reputation: 1 ksearcy Good Standing Member
Did any of you check the fit along the bottom of the headlight assembly after you finished changing bulbs. I had my headlights out while I was installing Phillips DRLs on the triangular panels below, when I put the headlights back, I noticed that there is a small gap below the assembly. After a lot of wrestling with it I was able to make it fit a little better but it still looks like a place for water to enter on rainy days or at the carwash. It seems like there should be a rubber gasket below the light assembly, but of course, there is not.
ksearcy is offline
