Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any 2012's losing weight?
Old 11-20-2012, 01:46 PM   #46
Focus YBTC
Focus YBTC's Avatar
Fan#: 97107
What I Drive: 2012 Yellow Blaze Tri-Coat Titanium
Points 710, Level 14
Points: 710, Level: 14 Points: 710, Level: 14 Points: 710, Level: 14
Level Up 10% Completed
FF Reputation: 1 Focus YBTC Good Standing Member
Originally Posted by Tommyatomic View Post
Well in the case of the Focus ST-R dont forget the weight savings from dropping support for cargo and passengers.
I would assume it also has dropped the fuel tank in favor a fuel cell and surge tank. Also the weight savings from an AC delete, heater core delete, MFT + dash delete, passenger and rear seat delete.
I can only guess that if the engineers behind the ST-R were worth their paycheck the ST-R probably uses an oil cooler combined with a smaller alloy radiator for better cooling while saving weight.
The list of things deleted from a purpose built racecar gets long and frequently purpose built racecars are seamwelded.
Well since the ST-R still weighs approximately 2700 pounds, at first glance it looks like they didn't save a whole lot of weight by dumping all that stuff. Considering that they are starting with an ST that weighs significantly more than a regular Focus (ST curb weight is 3,223 lbs.) it's not bad at all.
Focus ST-R
TECHNICAL DATA
Powertrain
• 2.0L EcoBoost I-4
• 250 hp est.
• 250 lb.-ft. of torque est.
• Ford Racing custom exhaust
• Ford Racing engine calibration
• Ford Racing high capacity radiator
• Ford Racing clutch
• Ford Racing oil to air oil cooler
• Remote oil filter
• 6-speed manual transmission with limited-slip differential
Chassis
• Weight – 2700 lbs.
• Structural performance: over 20,000 lb.-ft/degree (torsional)
• Seam-welded steel unibody with integrated FIA-certified safety
cage.
Front Suspension
• AST performance coilover adjustable dampers
• Adjustable camber plates
• Ford Racing upgraded sway bar with adjustable end links
• Upgraded bushings
Rear Suspension
• AST performance adjustable dampers
• Control-blade multilink rear suspension
• Ford Racing upgraded swaybar with adjustable end links
• Upgraded bushings
Steering
• Electric steering with unique Ford Racing calibration
Brakes
• Front: 336mm 2-piece rotors with race pads
• Rear: 271mm production with race pads
• Ford ABS with unique Ford Racing calibration
Wheels & Tires
• 18-inch BBS CF 1-piece cast alloy wheel (Anthracite)
Fuel System
• ATL® 18-gallon fuel cell with custom single-dry-break system
Exterior
• Brake cooling ducts
• Hood pins
• Ford Racing front/rear tow hooks
Interior
• Ford Racing lightweight wiring harnesses
• RECARO Pro Racer HANS® racing seat
• AiM MXL Pista GPS-based data system
• Ford Racing short throw shifter
• Ford Racing fire suppression system
• Ford Racing 6-point safety harness
• Ford Racing driver safety nets
• Ford Racing steering wheel with quick release
• Custom center panel with switches
https://docs.google.com/viewer?a=v&q...JZg53yhbUyUCCw
Focus YBTC is offline
