Old 11-20-2012, 10:32 AM   #2500
Dysan911
Fan#: 95746
What I Drive: 2012 White, Focus Titanium
FF Reputation: 2 Dysan911 Good Standing Member
Originally Posted by copernicium112 View Post
To receive texts on an iPhone with iOS6 try this (note I did a master reset the night before but don't know that it is necessary):
1) Delete your phone from the car. Delete Sync from your phone.
2) Turn the phone off and on again (just off/on, don't need to reboot the phone). Turn the car off and on again.
** Don't know if the above two are necessary either but I figured why not start "clean".
3) Pair your phone fresh w/MFT. Let it do its thing (phonebook loading, voicemail #, 911 assist, etc.)
4) On your phone, turn BT off. Turn it on again.
5) Hit "connect" on the MFT screen to reconnect BT.
6) Go into the settings screen for Sync (little arrow to the right of Sync).
7) Set Notifications to "On".
8) Back up a screen and turn BT off again. Turn it back on.
9) Hit "connect" on the MFT screen again to reconnect to BT.
Have someone send you a test message and see if it works (did for me). Still can't send messages but I am not done with trying to find a workaround for that one. Who knows? I may be able to, I may not. I should also note that my BT call quality "breakthrough" was noticed after I did this procedure. I am chalking it up to the master reset from the night before but there is always the possibility that this fiddling around with the BT settings had something to do with it.
I tried this exactly and it doesn't work at all for me. I just got my car back from the 3.5.1 update. I did a master reset prior to leaving the dealership. When I got home I setup my phone and ran through your procedure. Where it fails is there is no "Set Notifications" when you click the little arrow next to Sync . #6 and 7 on your list.
When I click the Messaging on MFT. It clearly states the phone connected does not support Bluetooth messaging.
2012 FF Ti HB Platinum White Tricoat, Built 12/11, 401A + Parking Technology Package and MFT w/NAV at 3.5.1
Dysan911 is offline
