Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford focus window help.
Old 11-20-2012, 09:55 AM   #6
Striings
Fan#: 106445
What I Drive: Ford focus
FF Reputation: 1 Striings Good Standing Member
Originally Posted by Kipp View Post
you can test at the switch as well to see if it has power coming in to it and out. you'll just need to know which wires to test to do that. easiest way to test electrical is usually start at the end (motor) and then work your way back to the source if needed. do you hear any sound from it when the switch is activated that would lead you to believe that the motor is jammed?
No noise. I have a feeling the motors not working. I doubt it's the fuse cause the passenger works and I think they run on the same fuse. How would I know if the regulator is jammed or not working? I have a test lead which lights up if their is power... If it don't light up then there's no power.
Striings is offline
