Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - TSB 12-11-01 Posted Today - MFT v3.5.1
Old 11-20-2012, 09:16 AM   #212
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Originally Posted by TehMark View Post
This was my exact situation. I'll try to use spotify a bit more this week and let you know if I see it happen again because you're right. It is a very intermittent issue.
Interesting that you both report it (even though yours seems to be fixed after the reset TehMark) using Spotify. Either of you tried other apps and see the same results? I tried Spotify after I read TehMark's post and got no skipping (but I only did a little under an hour of streaming). I use the freebies for all my streaming apps so I don't have anything cached when I stream. I have had it happen, very rarely, with Pandora and Slacker. I tend to think that has more to do with a losing/regaining a signal though. It also doesn't count against my hourly skips when it happens so I tend to believe it is on the app's end. If MFT was causing the skip I would think it show as a skip in the app.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
