Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford focus window help.
Old 11-20-2012, 09:10 AM   #5
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
you can test at the switch as well to see if it has power coming in to it and out. you'll just need to know which wires to test to do that. easiest way to test electrical is usually start at the end (motor) and then work your way back to the source if needed. do you hear any sound from it when the switch is activated that would lead you to believe that the motor is jammed?
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
