Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Trying to Install
Old 11-20-2012, 02:23 AM   #12
marcanjelo7
marcanjelo7's Avatar
Fan#: 65638
What I Drive: 2001 Blue SE
Points 502, Level 10
Points: 502, Level: 10 Points: 502, Level: 10 Points: 502, Level: 10
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 1 marcanjelo7 Good Standing Member
Originally Posted by Magus2727 View Post
^^^ this. The second 02 just does a comparison between the per cat. Its to measure if the cat is working. To my understanding it does not play in any way to fuel mapping or anything else except if the CAT is working. You can get 02 bungs from shops to weld in. The EGR is harder unless you canabolize it off your old system. Its a weird thread type to match up. The bung just gets installed before and after in the welded on straight pipe sections.
cool i knew the shop didn't want to mess with it..thanks for the help guys hopefully I can get this to another shop who can do this for me I don't see anything that should put their business at risk.. with adding the bungs and all hopefully this should work!
01 FOCUSED!
marcanjelo7 is offline
