Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Speedo doesnt work but replaced everything.
Old 11-19-2012, 11:14 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,328, Level 93
Points: 23,328, Level: 93 Points: 23,328, Level: 93 Points: 23,328, Level: 93
Level Up 98% Completed
Forum Activity 11%
Activity: 11% Activity: 11% Activity: 11%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by CBC&MLGZX3 View Post
my biggest being that the speedometer keeps jumping and then going to zero. odometer also blanks out occasionally. So I have replaced the Vehicle Speed Sensor, the coil pack along with wires and plugs.
Most times replacing those parts should fix this problem. The fact it didn't means it's probably in the wiring. Unfortunately there's no easy way to test it. What you'll probably end up having to do is replace the wiring from the VSS to the ECU.
I also have oil coming out of my oil filter which has been going on for a while.
Umm.
What?
I surely hope you misspoke there and meant Valve Cover Gasket.
Any oil leaking from the oil filter is very bad and should be fixed immediately. Do not drive the car until it is fixed.
Its ruined about 3 driver side motor mounts since i began driving the car. does anyone have an answer to this problem?
Many have had back luck with parts store brand motor mounts. But many have had good luck with Motorcraft mounts.
Solution, replace with factory mounts.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
