Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/F Ratio Guage Questions
Old 11-19-2012, 10:34 PM   #3
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
Originally Posted by Magus2727 View Post
I think the best way to do it is to install a new bung and wire up a dedicated O2 sensor. The bungs usually only cost $15 and a weld shop should be able to install one for 20 bucks or so. If you know electronics you can add a buffer stage between the O2 sensor and the A/F gauge do you dont change the impedance of the line.
A Tune does not make it not smog legal as long as you dont disable systems. And the only system I believe that would violate this would be if you disabled the EGR system.
I would get a triple and measure you oil pressure also...
That sounds like a better idea. How would I wire up a "buffer stage?" It sounds like a more feasible option.
Andrews-bad-SE is offline
