Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/F Ratio Guage Questions
Old 11-19-2012, 09:08 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,129, Level 77
Points: 14,129, Level: 77 Points: 14,129, Level: 77 Points: 14,129, Level: 77
Level Up 20% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
I think the best way to do it is to install a new bung and wire up a dedicated O2 sensor. The bungs usually only cost $15 and a weld shop should be able to install one for 20 bucks or so. If you know electronics you can add a buffer stage between the O2 sensor and the A/F gauge do you dont change the impedance of the line.
A Tune does not make it not smog legal as long as you dont disable systems. And the only system I believe that would violate this would be if you disabled the EGR system.
I would get a triple and measure you oil pressure also...
Magus2727 is online now
