Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear hub ass'y replaced: Already going out <5000 miles
Old 11-19-2012, 08:40 PM   #20
amc49
Fan#: 96610
Points 6,547, Level 52
Points: 6,547, Level: 52 Points: 6,547, Level: 52 Points: 6,547, Level: 52
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 74%
Activity: 74% Activity: 74% Activity: 74%
I would consider the fact that rolling drum on the last final tighten means that you are exerting torquing force also into the rear suspension in the form of twistup load, that amount of load will be subtracted from your actual nut torque regardless of what your wrench says. Meaning you won't have full torque there....
From like 75 ft. lbs. on up I have wheel bolted on, car on ground, brakes and engine on and someone standing on brake. The only way to guarantee pretty much full torque on nut itself.
amc49 is online now
