Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Affordable 2013 Focus brake upgrade
Old 11-19-2012, 06:49 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,975, Level 94
Points: 23,975, Level: 94 Points: 23,975, Level: 94 Points: 23,975, Level: 94
Level Up 63% Completed
Level up: 63% Level up: 63% Level up: 63%
Forum Activity 100%
FF Reputation: 79 felixthecat Excellent Standing Member
Originally Posted by bwh13 View Post
I've discovered what looks to be a simple way to upgrade the front rotors to 300mm using factory parts with either a modification to the mounting bracket or using a machined part to allow the use of a slightly smaller diameter bolt. I think the stock caliper may fit, but if not then the new caliper uses the stock pads.
I have a 2013 with the 16" wheels and will be test fitting the upgrade on it as soon as I get the parts.
Your right down there, I'd be hitting up Todd at TCE.
felixthecat is offline
