Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear hub ass'y replaced: Already going out <5000 miles
Old 11-19-2012, 04:49 PM   #19
G Ford Fan
Fan#: 80771
What I Drive: 15' Silverado 4x4, 08' Focus SE
Points 2,547, Level 30
Points: 2,547, Level: 30 Points: 2,547, Level: 30 Points: 2,547, Level: 30
Level Up 65% Completed
Forum Activity 9%
FF Reputation: 0 G Ford Fan Newbie
Originally Posted by elsolo View Post
You are also supposed to rotate the brake drum 10 times in the opposite direction while tightening the nut, to avoid damage to the bearing. (per the Ford manual)
the above is 100% correct and I also do just that.
I spin the drum both directions several times as I am torquing the bearing hub nut down.
This helps to seat the bearing properly and is a very important step.
G Ford Fan is offline
