Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clutch slipping some; master cylinder / relief valve?
Old 11-19-2012, 03:09 AM   #6
amc49
Fan#: 96610
Points 6,682, Level 53
Points: 6,682, Level: 53 Points: 6,682, Level: 53 Points: 6,682, Level: 53
Level Up 66% Completed
Forum Activity 100%
Uh, technically there IS a relief valve, the compensation port at master, if clogged or corroded it could easily hold the clutch fingers down. I don't screw with hydraulic clutches much but the cylinders are same basic design as brake and I've seen plenty of brake cylinders with that port clogged pretty solid to lock brakes up and car won't budge.
Worn disc most likely.
amc49 is online now
