Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Downstream O2 Sensor Wiring
Old 11-19-2012, 01:34 AM   #4
amc49
Fan#: 96610
Points 6,932, Level 54
Points: 6,932, Level: 54 Points: 6,932, Level: 54 Points: 6,932, Level: 54
Level Up 91% Completed
Forum Activity 100%
Screw how the factory does it, you know the wires should not touch axle through its' travel, simply restrain harness in some way so it doesn't. I redo the factory setup all the time if I see a problem to come, the clips they use break all the time and hard to find exact replacement. Extra tiedowns, extra harness loops, whatever you got lying around. I don't hesitate to drill a hole to slip a plastic wiretie through if I think harness needs more space from moving parts.
amc49 is offline
