Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil monitor reset issue
Old 11-18-2012, 05:46 PM   #3
Darth_Focus
Fan#: 104539
What I Drive: 2012,Tuxedo Black, Titanium
Points 2,789, Level 32
Points: 2,789, Level: 32 Points: 2,789, Level: 32 Points: 2,789, Level: 32
Level Up 26% Completed
FF Reputation: 1 Darth_Focus Good Standing Member
Originally Posted by Stlouis1 View Post
Line one is where you are making the mistake.
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP button for two seconds without pressing the brake pedal. Do not attempt to start the engine.
2. Press both the accelerator and brake pedals at the same time. 3. Keep both pedals
fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be displayed.
5. After 25 seconds, the Service: Oil reset complete message will be displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to turn the vehicle off completely.
I'm doing exactly that. I hold the start button for two seconds, then without releasing it I press both pedals at the exact same time and the engine starts to crank.
Darth_Focus is offline
