Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Interior Lighting Question
Old 11-18-2012, 03:58 PM   #3
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,912, Level 26
Points: 1,912, Level: 26 Points: 1,912, Level: 26 Points: 1,912, Level: 26
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
FF Reputation: 1 Bogey Good Standing Member
Originally Posted by dutd33 View Post
So I did a quick search here and I couldn't find anything, so I was wondering if anyone knows:
When I unlock the car, I believe the interior lights used to turn on by themselves. If I open the door it would turn on as well. It doesn't know. When I open the door it will turn on by only AFTER I've started the car.
Does anyone know how to change this? I've looked in the manual but this is all it says:
INTERIOR LAMPS
Dome/map lamp
The dome lamp will turn on when:
any door is opened.
the remote entry controls are
pressed and the ignition is off.
To manually turn on the dome lamp and/or map lamp(s):
press to activate the dome lamp.
press to activate the map lamp(s). Some map lamps have a split
switch.
Rear dome lamp
Turn your door dome light switch on your headliner on then off, same thing happen sometimes to me if my gf turns on the lights, and press' the wrong button.
Bogey is offline
