Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Heat not working.
Old 11-18-2012, 01:34 PM   #16
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,378, Level 100
Points: 31,378, Level: 100 Points: 31,378, Level: 100 Points: 31,378, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Shucks Dang!
Your results just reminded me of hearing that it's a "switched ground" system...
So, remembering the no power at the motor result you got, the culprit is likely in the power supply side.
Blade type fuses have test ports on the top, you can probe for power on both sides without removing them to both check the fuse & see if the circuit has power...
Luck!
sailor is offline
