Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Heat not working.
Old 11-18-2012, 11:26 AM   #15
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by sailor View Post
Fuse, Switch, resistor, motor.
In order of ease to check, you already checked for power at the motor - so next check the fuse for power on both sides (installed) - then look for power at the resistor pack & lastly the switch (just 'cause it's hardest to access).
FWIW, a good procedure with the meter is to test a known good 12v. source, to make sure you've got a good ground & the meter is working/set right.
Just hooking to metal doesn't always work due to ungrounded parts or poor connections. (getting fooled is easy, getting dependable results takes some effort)
thanks , i tested my other focus' heat at the blower motor and when the switch was off both wires read about 11.5 then with the switch on 4 one wire read 11.5 the other read 0.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
