Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear Wheel Bearing: Replace Bad One or Both?
Old 11-18-2012, 10:25 AM   #8
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,903, Level 100
Points: 31,903, Level: 100 Points: 31,903, Level: 100 Points: 31,903, Level: 100
Forum Activity 100%
amc - agreed!
Guess I need to clarify my reasoning here.
Note the last comment in my FIRST response, assuming that the 2000 Focus was on it's original rear brakes, and had a dozen years & quite a few miles on it - When one rear bearing needs replacement you probably will end up doing a rear brake job.
Now with that bearing pressed into the drum instead of having a separate hub, the easiest full brake job includes new drums with bearings. If someone was planning to keep the car, they probably wouldn't have to worry about any brake or bearing issues in the rear again.
Low Budget Quick Fix - try to get the drum off on the bad bearing side without much damage to the brakes, have a new bearing pressed in & reassemble. Probably could get away with that for now, depending on Luck, Skill, and how much actual wear on the car.
If it wasn't for the pressed in bearing design, replacing more than the bad one wouldn't be recommended - Unless a shop wanted to make money, or the car owner wanted a "belt & suspenders" job, just CHECKING the other would be adequate...
As amc commented, each new part CAN be a crap shoot these days....
sailor is offline
