Old 11-18-2012, 11:15 AM   #2497
copernicium112
Fan#: 87742
What I Drive: 2012 Sonic Blue Ti Sedan
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 4 copernicium112 Good Standing Member
Originally Posted by Dysan911 View Post
Oh and how did you get the incoming txt'ing to work? I thought after the 3.5.1 update the messaging now simply states it's not functional with the Iphone5. Having that working partially would be great.
To receive texts on an iPhone with iOS6 try this (note I did a master reset the night before but don't know that it is necessary):
1) Delete your phone from the car. Delete Sync from your phone.
2) Turn the phone off and on again (just off/on, don't need to reboot the phone). Turn the car off and on again.
** Don't know if the above two are necessary either but I figured why not start "clean".
3) Pair your phone fresh w/MFT. Let it do its thing (phonebook loading, voicemail #, 911 assist, etc.)
4) On your phone, turn BT off. Turn it on again.
5) Hit "connect" on the MFT screen to reconnect BT.
6) Go into the settings screen for Sync (little arrow to the right of Sync).
7) Set Notifications to "On".
8) Back up a screen and turn BT off again. Turn it back on.
9) Hit "connect" on the MFT screen again to reconnect to BT.
Have someone send you a test message and see if it works (did for me). Still can't send messages but I am not done with trying to find a workaround for that one. Who knows? I may be able to, I may not. I should also note that my BT call quality "breakthrough" was noticed after I did this procedure. I am chalking it up to the master reset from the night before but there is always the possibility that this fiddling around with the BT settings had something to do with it.
.......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you.
copernicium112 is offline
