Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Heat not working.
Old 11-17-2012, 05:07 PM   #14
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,433, Level 99
Points: 29,433, Level: 99 Points: 29,433, Level: 99 Points: 29,433, Level: 99
Level Up 66% Completed
Forum Activity 100%
Fuse, Switch, resistor, motor.
In order of ease to check, you already checked for power at the motor - so next check the fuse for power on both sides (installed) - then look for power at the resistor pack & lastly the switch (just 'cause it's hardest to access).
FWIW, a good procedure with the meter is to test a known good 12v. source, to make sure you've got a good ground & the meter is working/set right.
Just hooking to metal doesn't always work due to ungrounded parts or poor connections. (getting fooled is easy, getting dependable results takes some effort)
Luck!
sailor is online now
