Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Shockingly low mpg numbers reported for 2013 Focus
Old 11-17-2012, 01:42 PM   #19
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 19,979, Level 89
Points: 19,979, Level: 89 Points: 19,979, Level: 89 Points: 19,979, Level: 89
Level Up 26% Completed
Forum Activity 45%
Activity: 45% Activity: 45% Activity: 45%
FF Reputation: 25 Elizabeth Great Standing Member
It all is how many stop lights, and driving stop and go. vs never having to stop.
100%
If you reset your in dash mpg you can see the mpgs drop every stop light,and every time you have to reaccelerate. simple physics.
It take a lot of enegy to accelerate. having to do it over and over every few minute eats up an amazing amount of gas.
So does sitting idling. but not nearly as much as accelerating.
So say you have a city commute of three miles at 35 to 40mph with only one stop. Your mpg over that distance will be in the 38mpg range. The same distance at rush hour, with a stoplight every other block..Your mpg will be in the low 20's at best.
Same car. and person.
THAT is the only difference.
Yeah mashing the pedal makes it worse, but the real problem is the stopping and accelerating over and over.
Ther is no conspiracy, no magic involved. Just stopping and accelerating. is the problem.
I would also say that most cars I had driven this issue was never so clear as it is in the 3rd gen Focus.
Probably has to do with the high mpg which CAN be gained, vs the usual mpgs.. and the way the engine is designed etc.
Elizabeth is offline
