Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clutch slipping some; master cylinder / relief valve?
Old 11-17-2012, 10:22 AM   #1
LugNut
LugNut's Avatar
Fan#: 92146
What I Drive: 2001 White Sedan
Points 2,335, Level 29
Points: 2,335, Level: 29 Points: 2,335, Level: 29 Points: 2,335, Level: 29
Level Up 24% Completed
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 1 LugNut Good Standing Member
Question Clutch slipping some; master cylinder / relief valve?
The 2001 SE Sedan, with the SPI that I rebuilt and put in a new clutch about a year ago, now has a slipping clutch. The driver (not me) is very experienced with manual transmissions, so I thinking it's not from driver error.
I just had the car for a bit this morning. There's no leakage of oil from the vent at the bottom of the bellhousing, so a bad engine rear seal is not likely.
From the FSM, the hydraulic clutch is not adjustable. Clutch pedal operates correctly. Hydraulic fluid in the shared reservoir (brakes and clutch; not a better idea!) is clean and full.
From a test drive, it is slipping some in all gears, but does slowly engage. If not a bad clutch set ($700+ by a shop), my other guess is a bad/clogged hydraulic pressure relief that is slowing the release of the throw-out bearing. I'm also assuming the relief valve is part of the master cylinder.
Sound possible? Or better yet, solved the same yourself?
A new master cylinder is only $35, but a pain to install. I see this good thread on how to do it:
Replace master cylinder clutch
Thanks!
LugNut
Fixed Up a white 2001 P-code SE Sedan
including rebuilding the SPI (see my threads)
LugNut is offline
