Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Datalogging AEM Digital Boost Gauge
Old 11-17-2012, 06:20 AM   #1
mj22
Fan#: 32067
What I Drive: 2003 silver 2.0. zetec
Points 459, Level 9
Points: 459, Level: 9 Points: 459, Level: 9 Points: 459, Level: 9
Level Up 18% Completed
FF Reputation: 1 mj22 Good Standing Member
Hi Guys,
I was just wondering if anyone has had any success datalogging the analog output from an AEM Digital Boost Gauge (30-4406).
I have wired up my Xcal 3 to datalog the analog output, 0-5 volts that the gauge supplies and attempted to apply this equation to the raw voltage signal:
*Equation*: PSIA=12.5*(volts)-6.25* scale: .5v-4.5v = 0-50psia
which should then provide the boost.
I'm running a JRSC which sees 10 psi at redline. The boost level is indicated on the gauge however applying the formula to the analog output I don't get an accurate boost figure to datalog.
Can anyone advice an amendment to make to the above formula or possible reason the analog output may not be providing an accurate signal for datalog?
Thanks for the help.
Mike
mj22 is offline
