Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problems with ESP - Traction Control
Old 11-16-2012, 05:53 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,184, Level 93
Points: 23,184, Level: 93 Points: 23,184, Level: 93 Points: 23,184, Level: 93
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
"tsssss" sound to me would indicate the rotor is moving/flexing under cornering loads. Typical sound of a stone stuck in a pad, worn pads, rust buildup, improperly TQ'd lugnuts, worn wheel bearing or any other loose part you may thing of attached to the wheel.
Now the fact that the traction lamp comes on, to me that points more towards a bearing issue. There is a specific 'air gap' between the Wheel Speed Sensor and the Tone Ring. This is a fixed clearance. But if a bearing is worn/loose this clearance can move/grow. I can see where this could cause a lamp to light up.
But seems that if a bearing were bad you'd notice it under other conditions.
So I'm kinda at a loss as to what exactly it can be. But the simple things are making sure everything is tight and TQ'd properly. Jack the car up and wiggle the tire from top to bottom, there should be no play at all. If there is, it points to a bearing.
Also make sure the axle stub is tight, something like 233ft/lbs IIRC.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
