Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What causes my coil pack to crack.
Old 11-16-2012, 04:56 PM   #3
markmann1
Fan#: 106315
What I Drive: 2000 SE Black
FF Reputation: 1 markmann1 Good Standing Member
Originally Posted by 6SPD_soul View Post
I'm pretty sure the cracking is actually the spark going to ground through the coil pack body, for this to happen there'd have to be really high resistance somewhere in the wires or plugs, or your wire routing is not right. To begin with I'd ohm the plug wires and make sure none of them are open, resistance will be in thousands of ohms but probably shouldn't be higher than 5K or so given the length of the wires. I have Bosch wires and they were all at 2500 or so when new.
Did this happen once and then you replaced the wires and plugs and it keeps happening to brand new coil packs?
EDIT: One other thing to check is all the wiring going to the coil pack, these wires are known to break and cause problems, so give that a good visual inspection.
All brand new Bosh wires, plugs. yes it happens to brand new coil pack. Brand new alternater and die hard battery.
markmann1 is offline
