Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear wheel bearings
Old 11-16-2012, 10:22 AM   #1
Yellow Blaze 72
Yellow Blaze 72's Avatar
Fan#: 88536
What I Drive: 2012 Yell. Blaze Focus SE hatchback
Points 885, Level 15
Points: 885, Level: 15 Points: 885, Level: 15 Points: 885, Level: 15
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 1 Yellow Blaze 72 Good Standing Member
Rear wheel bearings
I took my Mellow Yellow in because of a rubbing noise from the rear. If it had a drive shaft I'd have called it a bad u-joint noise. Turned out to be a bad wheel bearing. The dealer replaced it no problem and said they checked the other side and found it to be OK.
I'm wondering how many other folks have had to replace the rear wheel bearing? The car has 22255 miles on it. I've never had any other car that needed even one bad wheel bearing!
Yellow Blaze 72 is offline
