Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Alignment Question
Old 11-15-2012, 08:04 PM   #3
RSV 02 Focus
Fan#: 105522
What I Drive: 2002 Green ZTS
FF Reputation: 1 RSV 02 Focus Good Standing Member
Originally Posted by 6SPD_soul View Post
The camber numbers are acceptable IMO, and while the toe appears to be way off at both ends of the car nothing aftermarket should be required to get it back in spec. Although the stock rear toe adjustment is just an eccentric bolt, so it's range of adjustment is way more limited than the tie rods. I'm surprised you were able to get those numbers without them talking you into getting an alignment on the spot.
I guess I don't know if the stock setup is capable of getting that right rear back in spec. I suspect it would though.
Thank you for your response. I wanted to get it checked first to see if I needed the rear camber bolts. Also, my mother in law just ordered new tires so we plan to get it aligned when they're installed. If the rear camber is OK in your opinion, it looks like we'll have them do an alignment then.
Thanks again, I appreciate it!!
Roy
RSV 02 Focus is offline
