Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Alignment Question
Old 11-15-2012, 06:44 PM
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 3,033, Level 33
Points: 3,033, Level: 33 Points: 3,033, Level: 33 Points: 3,033, Level: 33
Level Up 89% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 24 6SPD_soul Great Standing Member
The camber numbers are acceptable IMO, and while the toe appears to be way off at both ends of the car nothing aftermarket should be required to get it back in spec. Although the stock rear toe adjustment is just an eccentric bolt, so it's range of adjustment is way more limited than the tie rods. I'm surprised you were able to get those numbers without them talking you into getting an alignment on the spot.
I guess I don't know if the stock setup is capable of getting that right rear back in spec. I suspect it would though.
6SPD_soul is offline
